Driver Side Power Window
Google
Web AF
Nancy5048
08-11-2005, 12:38 PM
This goes out to Teddy77 or anyone else who could give me some advice. I'm having the exact same problem that Teddy77 described in his post and wanted to know what he did to fix this. The driver side window on my 1999 Blazer is stuck in the up postion. When I toggle the power window button it just clicks and nothing happens. I wanted to know if it was diffenitly the door regulator or the motor. I made the mistake of first replacing the control console thinking that it might be the push button itself to no avail.
Thanks
s10blazerman4x4
08-11-2005, 01:17 PM
Have you checked the fuses?
Nancy5048
08-14-2005, 10:19 AM
Yep. That's the first thing that I did. It appears that only one fuse according to the block diagram on the fuse panel controls all of the windows and all of the other ones run just fine.
dbldown768
08-29-2005, 11:36 AM
you know i have the same problem. i took apart the door and tapped the motor with a hammer while pushing the button down and the window works again. it seems like every once in a while when i roll the window up it will make a click sound. if i dont quickly reverse the window its like the motor gets stuck... but this is just a temporary fix.
Nancy5048
08-29-2005, 01:34 PM
Thanks,
I'll give that a try this weekend. It's worth a shot before I have to take it into the dealer and pay big bucks....
Nancy5048
09-04-2007, 10:08 PM
Thanks,
I'll give that a try this weekend. It's worth a shot before I have to take it into the dealer and pay big bucks....Just an update. Better late than never, I guess. I simply banged on the driver side door with my hand about where I thought that the motor was and the window has worked ever since.....
ZL1power69
09-05-2007, 09:06 AM
glad its working for you now but your thread is now over 2 years old.
Google
Web AF
