door panel
Google
Web AF
xxtomorrowsliexx
08-10-2005, 10:33 PM
i have a 2002 grand am gt coupe. i have an extremely bad rattle on the right door panel near the speaker. i am writing to ask anyone who knows how to remove the door panel to please let me know so i can take off the panel and try and fix the annoying as hell rattle. anyone who knows please respond...or anyone with a similar problem you are welcome to respond as well....thanks a bunch
Ridenour
08-10-2005, 11:20 PM
first, you need to remove the bezel screw behind the door handle. Remove that, and pop / slide out the tray. Next, pry up the controls, and disconnect them. Unscrew the screw exposed down in the cavity. Next, pry up the reflector on the edge of the door, and remove the philips head deep behind it. Remove the screw at the base of the door grip-handle as well. Remove the triangle-shaped tweeter housing at the top by squeezing it and pulling. Now you can work your way around the door, pulling outward and pulling out the christmas tree fasteners. (it will sound like your breaking things, but you're not). Good luck.
xxtomorrowsliexx
08-11-2005, 12:06 PM
got it no problem... speaker had fallen out of door mount..good directions...thanks alot bud
Ridenour
08-11-2005, 03:19 PM
no problem - glad you resolved the problem.
pysco
08-11-2005, 06:21 PM
whould it be the same for the rear door except for the tweeter.
Ridenour
08-11-2005, 07:30 PM
It should be; yes.
Google
Web AF
