05 Rear Bumper On An 02?doc5339 08-10-2005, 10:15 PM Anyone know if the 2005 Silverado rear bumper will fit on a 2002 Silverado? I can't see why it would not? dr_of_lovephd 08-10-2005, 11:09 PM You will probably need to check to make sure the brackets are the same. If they are the same, you should have no problem. bigbadram51 08-11-2005, 04:17 AM You will probably need to check to make sure the brackets are the same. If they are the same, you should have no problem. They are not the same. Brackets changed in I believe 04. Dont know why though. dr_of_lovephd 08-11-2005, 08:08 AM I do not know why Chevy does that. The 88-98 trucks look to have the same bumpers but the 88-93 and 94-98 bumpers are not interchangable. The only real difference between the bumpers is the brackets. doc5339 08-11-2005, 06:46 PM Will the 05 bumper fit on my 02 brackets, or would it require fabrication? bigbadram51 08-12-2005, 04:15 AM Will the 05 bumper fit on my 02 brackets, or would it require fabrication? I dont think it would just fit. You can modify anything, but safely I dont know. I am pretty sure GM in their infinite wisdom changed both. They decided they wanted to spend more money to fabricate a whole new part vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
