02 spark plugs!!!AaronHurd 08-10-2005, 05:48 PM how much life can be expected on stock spark plugs in a 02 5.3 tahoe nosefirst 08-10-2005, 08:23 PM how much life can be expected on stock spark plugs in a 02 5.3 tahoe If they are original plugs, I think they are AC. They are good plugs. Technically you should replace them every xxxxx miles? What is it guys?, 30K? What do they look like? I recently replaced mine in the Burb for the second time at around 100K. Lesson learned....don't use Bosh. Lesson learned....check the gap on "pregapped" plugs. AaronHurd 08-11-2005, 12:16 PM If they are original plugs, I think they are AC. They are good plugs. Technically you should replace them every xxxxx miles? What is it guys?, 30K? What do they look like? I recently replaced mine in the Burb for the second time at around 100K. Lesson learned....don't use Bosh. Lesson learned....check the gap on "pregapped" plugs. I'm pretty sure there the AC's. I have 75k on the truck and they are original.......I'm I way over due!! If 30K is the number then they need to be changed for sure. Also I don't want to spend the $ 17.?? something each at the dealera trip to napa or autozone!. do you know the AC part number.....Thanks Aaron GMMerlin 08-11-2005, 08:57 PM I'm pretty sure there the AC's. I have 75k on the truck and they are original.......I'm I way over due!! If 30K is the number then they need to be changed for sure. Also I don't want to spend the $ 17.?? something each at the dealera trip to napa or autozone!. do you know the AC part number.....Thanks Aaron Check your owners manual! Plug replacement isn't due till 100K vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
