Very high idlegrassr00t 08-08-2005, 05:24 PM I searched the forum and did not come up with anything regarding this. I have a 99' Passport and it lately it has had a very high idle (2000-2500rpm's). I changed out the Idle control valve and it still does it. The thing is if I disconnect the battery and let it sit for a bit and hook it up, everything seems fine (a little high 1100-1200rpms). It will stay that way all day. The next day same thing happens again (2000-2500rpms). Anyone have any ideas? Thanks in advance, James amigo-2k 08-08-2005, 06:22 PM Throttle body is full of carbon or the intake manifold gasket is bad. grassr00t 08-09-2005, 05:05 PM Throttle body is full of carbon or the intake manifold gasket is bad. Thank you. I will look into that this weekend. rodeo02 08-09-2005, 05:18 PM The idle-up switch on the power steering pump could also be stuck. Look for a small gray wire going to a fitting on the P-steering pump. Unhook that wire & see if the idle goes down. That idle up circuit is not needed. G/luck Joel grassr00t 08-10-2005, 09:47 AM The idle-up switch on the power steering pump could also be stuck. Look for a small gray wire going to a fitting on the P-steering pump. Unhook that wire & see if the idle goes down. That idle up circuit is not needed. G/luck Joel Thank you Joel. I will try that today. surferfletch 08-11-2005, 03:56 AM I had this happen one day. Idle all of a sudden went up to 2000 or so. I stopped at the store I was going to, shut it down. When I was ready to go, all was back to normal. I cleaned the TB later that day, and it hasn't happened again... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
