92 camaro still won't run
Google
Web AF
martikus
08-08-2005, 07:35 AM
ok i have done it all now, as i said in the last thread. i changed out the fuel pump, fuel filter, fuel relay and now the ecm. i still have the problem to where it will start and idaol for a few minutes, maybe 20 then stall, or if i am driving it for a few minutes, it stalls out to. someone said that it may be the ignition module but my car has a coil, and it is getting plenty of fire. gas is making it to the TBI, but it seems that injectors are not working, could this be the problem.
DaMoNe6969
08-09-2005, 12:36 AM
Your car has a coil And ignition module..
What makes you say you dont think your injectors are working??
martikus
08-09-2005, 01:55 PM
when i was able to get the car started, i watched the injectors, the one on the left sprayed ok,, not the best but ok, the one on the right was bearly spitting any gas out. where can i find the ignition module at?
Tuffdrvr88
03-04-2006, 01:03 AM
Take your throttle body off and have it rebuilt, tuned and re-sealed, it will run all the better for you.
bag91
03-04-2006, 01:10 AM
How bout a new throttle body?
Tuffdrvr88
03-04-2006, 11:33 AM
New ones are too expensive unless you have TPI and not TBI.
malletslinger
03-04-2006, 04:34 PM
Any seemingly isloated problem affects everything else.
Try some injector cleaner.
You might mant to take out the ones you now are bearly spitting out any gas and let some diluted injector cleaner soak in them for a while, then plug them back in and check to see if they are spraying any better... if yes, then add injector cleaner to your fuel and drive on that and see if your problem does away:grinyes:
PS3Camaro
03-04-2006, 08:15 PM
just sounds like ignition module or coil to me, I could be wrong, I'm a newb
malletslinger
03-04-2006, 11:05 PM
Being a newb doesnt matter, If you think you know the problem then you post your opinion, maybe you're right, maybe not...eather way, it marks another posibility of the list..:grinyes:
Also, WELCOME to the forum:icon16:
xgrungepedalx
03-05-2006, 12:28 AM
How is your oil gauge? Sometime if the oil pressure sending unit is acting up, it will disable the injectors. The reason being, that if you was to run out of oil your car will cut off to prevent engine lock-up. Probable not, but just another thought to throw around.
Google
Web AF
