Grand Am Won't Stay Rujnning
Google
Web AF
Lostone01
08-07-2005, 09:54 PM
Hi all. Here is a question for you all out there. I have a 94 Grand Am 6 cylinder. Now I ran this car hard everyday for a year with no major problems. I parked it a month ago to do some much needed work to it. Unfortunately I had no time to do it til now. But when I went to start the car, it will start up fine and go into reverse fine but when I try to put it into drive all it will do is spit and sputter and then shut off. It will not stay running in drive at all! Any ideas on what could be causing this? Anything would be helpful right now.
Terry
94 Grand Am...6cyl...approx. 170,000 miles
97 Hyundai Accent...4 cyl...86,000 miles
ctesla
08-08-2005, 08:18 PM
when you parked it a month ago, did you start it at any time through that month, or did it completely sit without being turned over?
fuel should not have gone bad that quickly, but how much was in the tank, and what octane rating?
try adding a couple of gallons of premium, and/or (you say you are doing some time needed maint.) fuel filter. and possibly pulling the fuel rail and spraying it and the press. regulator out.
...also, in my area, if I let my vehicle set for two nights up in the mountains, I have to make sure the rabbits and mice have crawled into the engine bay and started harvesting the wiring. I'm sure this probably isn't your case, but you may just check status of plug wires, as a vehicle can fire and idle as even a 3-cyl. (lopey even w/comp control)rather than a six; but won't stay running.
hope this helps,
ctesla
Lostone01
08-13-2005, 01:51 PM
Car has been sitting for a month but it has been started up. The car will start with no problems now BUT it wants to shut off when I put it into gear. After a while of running in idle, it will go into reverse but I can't get it to stay running in drive at all. As soon as I shift to drive it shuts down. It obviously has gas and starts. Any clue what could be causing this? The car ran very well and was a daily driver when it was parked.
xeroinfinity
08-13-2005, 05:21 PM
the TCC or a valve sticking. Do a search for TCC and you'll find some info, I'm certain. \,,/
Google
Web AF
