Wipers come on by themselves...
Google
Web AF
Semi retired
08-06-2005, 07:43 PM
Anybody have any suggestions to fix the wipers making one sweep when you start the engine, or one sweep when you turn the radio on?
Also, there must be a short or bad ground someplace as the gauge on the dash show "voltage" spikes when the brakes are on or the turn signal is flashing or you turn the heater on. I already replaced the battery, alternator and did the wipermotor circuit board upgrade.
Although the volt meter shows a low voltage.....the actual voltage at the battery is just fine.
HELP.......
PS this is a 1994 2500 4x4 pick up
Semi retired
08-06-2005, 09:05 PM
HELP.......
Answered my own question.....found a bad body ground from the battery to the body. Seems to fix voltage meter and other gauge voltage spikes and also the wipers coming on by themselves.....
Thanks anyways. Maybe somebody else has had this same problem, now you know the fix.
MoparSRT
08-16-2005, 11:07 PM
hey can u possibly tell where taht ground is becuz when i turn my wipers on tehy dont always turn on and i dont kno wat else to do. my cruise also acts up on its own. can u possible help me i have a 1992 K1500 4x4
Semi retired
08-17-2005, 01:24 AM
Check the ground wire from the battery post to the body. There are two cables from the negative side of the battery, one to the engine block, the other to the body. (inner right front fender). Clean the ground wire connection to the body.
Google
Web AF
