engine turns but doesnt startbortiz 08-06-2005, 04:13 PM i just bought a 93 grand am gtv6 for dirt cheap from a buddy that just wanted to get rid of it. he said it needed a new water pump and it was only running on 4 cylinders but still started and ran. the car did start but was very sluggish on the road, obviously. i changed the water pump, serpentine belt and all spark plugs and wires. after doing all the work i thought it would run like a champ, instead it just cranks no start. Could it be the bad coils? after the engine turns a few times it sounds like gas is being pressurized through the intake (pssss noise) please help. xeroinfinity 08-06-2005, 04:58 PM sounds like it could be a coil or two. If you have an old plug it works great , usually to see if they're all firing or not. double check all the wires , one could be crossed or the boot poped off the plug. I've had boots pop off just enough to not fire that plug. \,,/ GTP Dad 08-06-2005, 06:37 PM It certainly could be the coils but it could also be the ignition module under the coils. As for the noise you hear check the fuel pressure regulator, pull the vacuum hose and see if fuel is coming out. If so you will need to replace the FPR with a new one. One other thing, make sure the security light is not on as it could be causing the starting problem. bortiz 08-17-2005, 07:47 PM thanks for the reply GTP sorry it took long to respond, this car has become very frustrating. i found out the coils were ok and the module tested out ok as well. problem not there, but im going to check that fpr. and what do u mean about the security light?? oh yeah the firing order according to the chiltons book for the vin n car should be 165432 right. 1 4 2 4 6 5 2 1 3 5 3 6 (front of car) on mine looks like this 2 of them were # one coil blank which is correct??4 1 blank 6 3 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
