overheating ,timing belt tension ?mikel92220 08-04-2005, 08:10 AM runs fine for about 30 minutes. then it starts to get hot fast. put new thermostat, boiled out rad. changed fan clutch and it has low oil pressure amigo-2k 08-04-2005, 09:40 AM 1996. See the faq's. Other rodeo owners that have chased this problem with flushing and termostat and still have problems. The solution has always been a new rad. Cat Fuzz 08-04-2005, 08:30 PM Does it get hot only while sitting or while driving too? Make double sure the cooling system is filled. My truck was overheating while sitting too long and the only thing wrong was it wqas a bit low on coolant. Canucklehead 08-04-2005, 10:15 PM runs fine for about 30 minutes. then it starts to get hot fast. put new thermostat, boiled out rad. changed fan clutch and it has low oil pressure Your low oil pressure could very well be because of the overheating. Before I changed my fan clutch I had a couple of incidents where temp would increase and oil pressure would decrease if I was stuck in stop and go traffic. Once I got moving temp would always go back down to normal and oil pressure would go up to its normal value. Since replacing the fan clutch temp and pressure has been rock steady regardless of whether I'm stuck in summer traffic or not. As for your overheating problem, I'd have to agree with amigo-2k and suggest that a new rad may be the only solution. :2cents: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
