Help: 96 grand cherokee differential gasketstanleyeye 08-03-2005, 10:07 PM I find a small leak on my front differential, so I wanna replace the gasket. I am wondering if it does have a gasket, not the RTV. The NAPA and Autozone guys told me that there was only RTV, no real gasket... Thanks for help stanley dksob81 08-03-2005, 10:08 PM There is no gasket that I know of. use some BLACK RTV Sealant (it really doesn't matter the color they will all work just as good, but the BLACK will be less notiveable). stanleyeye 08-03-2005, 11:51 PM Many thanks for your reply I checked the Hanyes book. It does mention the RTV and gasket. It says "put a thin layer RTV, then put on the new gasket..." I am confused about this... There is no gasket that I know of. use some BLACK RTV Sealant (it really doesn't matter the color they will all work just as good, but the BLACK will be less notiveable). dksob81 08-04-2005, 08:16 AM The FSM (Factory Service Manual) for my 94 ZJ, Says to apply a bead of MOPAR Silicone Rubber Sealant on the housing cover. ALLOW THE SEALANT TO CURE FOR A FEW MINUTES BUT INSTALL THE COVER WITHIN 5 MINUES AFTER APPLYING BEAD. There was NO mention of a GASKET. I looked through the haynes and I saw it did say to apply a thin layer of Silicone sealant to the cover flange and press the new gasket into position on the cover. Just use the RTV Sealant it will work just fine. I do not believe anyone has a gasket for this. It's not mentioned in the FSM so I believe there is no need for it, I used RTV When I changed the fluid in my diffs a few months ago and I have no leaking from the cover. fredjacksonsan 08-08-2005, 01:04 PM Just make sure the surfaces are clean and smooth before starting the reassembly. jeeperphil 08-08-2005, 09:01 PM The rtv is also available now in a can that just press the nozzle and it comes out a lot easier than the tubes. I've used both and use only the cans now. there are no gaskets available that i know of. the rtv seems to work better anyway. Cam7 08-11-2005, 04:43 AM There is a gasket for the diff Ive seen it at one of the Parts stores cant remember which one. I always use Rtv gasket sealer works good. The Factory sevice Manual says to use RTV Like 81 said and mine is a 96. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
