96 legacy head gasket seepagegvtacoma 08-02-2005, 06:52 PM Is a little seepage from the head gasket cause for concerns? ken Will2 08-08-2005, 04:31 PM It all depends where the seepage is. I assume it's something you can see on the outside. Your head/heads probably aren't torqued down tight enough and that also can mean possible problems internally. gvtacoma 08-08-2005, 04:36 PM Thanks for that... ken It all depends where the seepage is. I assume it's something you can see on the outside. Your head/heads probably aren't torqued down tight enough and that also can mean possible problems internally. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
