93 s-10 hard start
Google
Web AF
bestaaron
08-02-2005, 03:33 PM
I have a 4.3 cpi and am having a hard time starting. I have to press the gas and it still takes about 10 cranks. once it starts it runs great. It has 170000 miles and I just did a major tune up. I replaced the fuel pump about 2 years ago and I replaced the fuel injection about a year and a half ago. Fuel mileage is great. Any help would be appreciated.
jackass#1
08-03-2005, 12:41 AM
hows the battery and alt?
bestaaron
08-03-2005, 01:59 AM
they are fine and I am getting spark when this is occuring. so I know it is probably fuel related. I don't want to replace the spider again, that's
pretty expensive.
jackass#1
08-03-2005, 06:19 AM
before you do that check you fuel pressure first. can you pull any codes? possible tps.
Elkaholic
08-07-2005, 05:01 PM
Did you change the fuel filter?
rustbucket
08-08-2005, 09:31 AM
Make sure the fuel pump runs when you first turn on the key. It gets its power through a fuel pump relay. If that relay is bad, the only way the fuel pump will run, is to get enough oil pressure. So a bad relay will cause hard starting.
bestaaron
08-08-2005, 07:50 PM
I have checked the fuel pressure and it's between 55-61psi. I am running out of ideas except for that pesky spyder? Anymore ideas before I take the plunge with the injection master piece?
jackass#1
08-09-2005, 12:04 AM
nope
Google
Web AF
