1997 Lumina Rear wheel ABS SensorRubicon1 08-02-2005, 03:56 AM I need to replace one of my rear wheel ABS sensors. I guess it's built into the rear wheel hub assembly. I have taken off the rear wheel drum and removed the four bolts to the hub assembly, but the hub will not come off. Is there anything else I should be doing? Do I need some type of puller on it? TIA Rubicon1 08-03-2005, 07:10 PM Has no one ever replaced a rear hub on one of these cars? jeffcoslacker 08-04-2005, 10:04 AM It's been a while. And not on one that new. jeffcoslacker 08-04-2005, 10:15 AM Rubicon1 08-04-2005, 09:54 PM Thanks for the reply. I seen that and thought it mounted flush. I finally got it off. There is a round portion sticking out from the rear that fits thru the backing plate. It was a somewhat tight fit and after rusting in place took a few hard hits with a hammer to loosen it enough to slid out. Next up Cam Position Sensor. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
