Chevy S10 Pickup 4.3L 1991 2wd truck
Google
Web AF
fatdaddy62
08-02-2005, 12:15 AM
I bought my son this truck. We are a bit frustrated as the truck stalls and quits running as if the computer shuts it down. I put new plugs, wires, rotor button, dist cap. I pulled the control module and had it tested. Adv Auto said it was good so I added dieletric grease and reinstalled the part. I had a chrysler van that had a MAP sensor go bad that behaved this same way. I have not seen check engine light come on. I replaced FF since it idles rough as well and has since we purchased the truck. Now I am getting killed by car insurance for a 16 yr old boy and am shotgunning the truck to see if I can keep my cost down. I need to verify that the check engine light comes on for a moment when the key is turned on. I am tempted to replace the MAP sensor and possibly the FPump (I checked it when it died on me going about 45 MPH after dring 15 minutes, it was delivering the fuel to the TBI. I don't have the pressure guage to test this but it seems to me the computer shuts it down after it hits a consistent operating temperature. After it sits for an Hour or so I can start it and drive a few miles. HELP I used to work at a service station and now the world of computers and sensors has left me without knowledge based strategies. Oh, I did listen for the Fuel pump and I can here it in the gas tank when the key is turned to the on position.
drdd
08-02-2005, 12:30 AM
have you cleaned the throttle body (w/ TB cleaner)?
have you cleaned the EGR sensor ? (Exhaust Gas Recirculation)
have you cleaned the IAC sensor? (Intake Air Control)
PCV and air filter ??
QUOTE=fatdaddy62]I bought my son this truck. We are a bit frustrated
as the truck stalls and quits running as if the computer shuts it down. I put new plugs, wires, rotor button, dist cap. I pulled the control module and had it tested. Adv Auto said it was good so I added dieletric grease and reinstalled the part. I had a chrysler van that had a MAP sensor go bad that behaved this same way. I have not seen check engine light come on. I replaced FF since it idles rough as well and has since we purchased the truck. Now I am getting killed by car insurance for a 16 yr old boy and am shotgunning the truck to see if I can keep my cost down. I need to verify that the check engine light comes on for a moment when the key is turned on. I am tempted to replace the MAP sensor and possibly the FPump (I checked it when it died on me going about 45 MPH after dring 15 minutes, it was delivering the fuel to the TBI. I don't have the pressure guage to test this but it seems to me the computer shuts it down after it hits a consistent operating temperature. After it sits for an Hour or so I can start it and drive a few miles. HELP I used to work at a service station and now the world of computers and sensors has left me without knowledge based strategies. Oh, I did listen for the Fuel pump and I can here it in the gas tank when the key is turned to the on position.[/QUOTE]
BlazerLT
08-02-2005, 12:40 AM
How about checking the timing with the timing wire dsconnected from the PCM under the dash.
Also, ever replaced the fuel filter?
Could be a fuel pump dying out too.
fatdaddy62
08-02-2005, 07:05 AM
I will likely try the fuel pump. The way it shut down right in the middle of driving really made it feel as though the computer shut it down. That's why I thought it was the map sensor like my crysler did. This may sound stupid but I have never cleaned an EGR or IAC sensor. How do I do that without damaging the parts?
Allbert
08-02-2005, 08:26 AM
Maybe check for contaminated fuel or a partially blocked inlet screen in the tank.
fatdaddy62
08-02-2005, 09:34 AM
I just measured and checked the ignition coil and pick-up coil both measured properly to the manual. I have removed the EGR valve and it is black on the inside but it will create a vaccum when I push on the diaphram and release. There did not appear to be any thing in-operable with it. Any suggestions. I am going to ohm meter the map sensor next.
BlazerLT
08-02-2005, 11:29 AM
Read my last post..
fatdaddy62
08-02-2005, 02:43 PM
BlazerLT Thanks. I don't have a timing light. I loaned it out and it never returned to me. Bother or neighbor I can't remember. After I got back to the truck again I cleaned the EGR and the other things. there has been no check engine light either. I am now half way through the Fuel Pump change. I cannot believe how difficult they make getting to the hoses to remove them. I am on the ground and using a jack to lower and support the fuel tank I did this on a Lumina APV I had and it was much easier. Oh well, probably should get back to it. Any suggestions where I could get a Cheap timing light? I priced a few and Advance did not even stock one.
fatdaddy62
08-02-2005, 02:52 PM
Good news with all the work I am doing I am getting to know this truck real good. I also cleaned the PCV valve, checked air filter and replaced the fuel filter that I mentioned earlier I believe. I did notice the vaccum lines were a bit fragile but I don't hear any hissing or see any holes. Back to the fuel pump, I think I am beginning to procrastinate. Later. Thanks for all your help.
fatdaddy62
08-02-2005, 10:05 PM
Finished the marathon put it all back and now have no fire not from the coil. When I measured it today it cheked exactly as the book said. I am really confused. No check engine light still but I did verify that it came on when you first crank the car. I measure the pickup coil and it too was what the book stated it should be. I have an unfriendly ghost in my truck. I was able to verify the fuel pump ran when I turned the key but it did not seem to flood the throttle body that I could see. Help !!!! My neighbor did have a timing light so If I ever get fire Ican check the timing.
BlazerLT
08-03-2005, 01:20 AM
No spark at all?
Ignition module or the coil is shot.
fatdaddy62
08-04-2005, 07:07 AM
I cannot access at work. I took the coil out last night and measured as it as the manual said to and bolted to the car I thought it measured bad. So I removed it and double chcked myself and it measures good. I measured it in circuit with the key on and there was power to the connectorthen I trace the line over top the ignition module and measured 12V in on that line with the key on. I pulled the ignition module out last night and was sending it to Adv, Auto to test it again. My book said to measure the TACH terminal with the key on. it said it was 'Taped back near the distributor. I removed the other module connector w key on and had voltage at one pin, (less than 10 I believe) and all others were low. I measured the coil wire and got about 8k I believe it was. I am tight on cash right now but if you think it is the module I will replace it. What if AA tests it and they say it is good. What would I look at next? Could the coil give sporatic readings and fool me from my ohm meter? is there something else I should check. Coolant Temp sensor was suggested by one trouble shoot guide.
fatdaddy62
08-04-2005, 07:10 AM
I forgot to mention that I measured the pickup coil again and it seemed ok. Hopefully the test at AA today will show the module from the distributor is bad and then I will be done with it. Study it and let me know if you have other ideas.
fatdaddy62
08-05-2005, 09:14 PM
Test concluded that the module is definitely good. I am thinking the ECM any opinions?
fatdaddy62
08-23-2005, 06:07 AM
I replaced the throttle position sensor and IAC and now the stalling while mid driving have ended. Fix one thing find another. I also had a plugged cat converter and drilled a hole to get some power back as it was a slow pig. Thankfully the Lord let me get there and poster from another spot on this site was right-on. that closes this one.
BlazerLT
08-23-2005, 03:43 PM
No, this is not closed.
you need to replace that CAT ASAP or you will be slowly ruining the engine.
The universal cats cost about 70-80 bucks and it should be done soon.
s10blazerman4x4
08-23-2005, 09:22 PM
http://cgi.ebay.com/ebaymotors/Blazer-Jimmy-Catco-Catalytic-Cat-Converter_W0QQcmdZViewItemQQcategoryZ33629QQitemZ7 987667191QQrdZ1QQsspagenameZWD1V
or
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&catref=C12&from=R10&satitle=catalytic+converter+blazer&sacat=33628%26catref%3DC6&bs=Search&fmmk=&fmmd=&fylo=&fyhi=&mppfqy=catalytic+converter+blazer&sargn=-1%26saslc%3D2&sadis=200&fpos=ZIP%2FPostal&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp=
fatdaddy62
08-24-2005, 07:13 AM
I bought one yesterday. Spoke with a shop and next wednesday is the earliest they can do it. I did drill a couple holes in the front flange of the old one. It runs 90% better but still stalls at lights some of the time. Thanks I did not know that would do that. What does it do? (can you tell I'm an engineer) My guess would be to foul up the exhaust and EGR areas.
BlazerLT
08-24-2005, 10:57 AM
It will put too much back pressure on the valves and could cause them to not be able to close, having them float and causing damage.
mercedestechball
08-18-2008, 08:37 AM
Hello,
I Would Not Buy And Replace The Fuel Pump Yet. I Had A Very Similar Problem With My Truck. Mine Was The Ignition Module Under The Distributor Cap. It Only Cost 30 Bucks And Is Alot Easier To Replace Than The Fuel Pump. The Ignition Module Is What Tells The Injectors When To Open. So If You Have Fuel To The Injectors And No Spray That Would Be The First Thing I Would Look At.
Mine Was An Intermitant Problem. Took A Couple Hundred Bucks In Parts And Alot Of Cursing To Figure It Out.
ZL1power69
08-18-2008, 10:32 AM
Welcome to the site. This thread is over 3 yrs old, please refrain from bringing back old threads.
Google
Web AF
