1990 chevy lumina euro 3.1 turns over does not start
Google
Web AF
markm2
07-31-2005, 06:14 PM
Hello! This is my first post here, but have done a lot of post reading.
Here is my problem 1990 Lumina Euro 3.1 with 154,000 miles my 16 year old daughters car died on the interstate outside of town. Was towed to our house, they thought it sounded like the fuel pump. Started to work on it the fuel pump seems to be fine when key is turned on you can here it humm for 2-3 seconds. I changed the fuel filter while apart turned key back on plenty of fuel came out into a fuel can, put back together. Before changing fuel filter released fuel system pressure, rechecked after fuel filter replacement I have a lot more pressure. I have also removed the easiest spark plug and I have spark and compression. Seem like no fuel getting to spark plug as it was dry. I have also checked the fuel injector fuses and they are fine. I hope someone can tell me what to check next to help solve this problem. Thanks for any advice.
Mark M
ctarmen2
08-01-2005, 09:05 AM
Hey Mark,
My first post here as well. I am having a similar problem to you. I being the handy mechanic that I am decided to change the plugs, wires and fuel filter in my 91 Lumina 3.1. After I put everything back together the car would not start. I was getting spark, but like you, it won't start. So, I had the coils, ignition module and crankshaft position sensor tested at the local Auto Zone. All of the items tested good. I went ahead and bought a crankshaft position sensor since it was pretty cheap. It still wouldn't start, so I had it towed to a local shop. It's been there for a week and the mechanic still can't figure it out. I know he's changed out the ignition control module and the wiring harness connecting to the module. He thought he had the problem fixed, but it died not long after starting it. He's still troubleshooting it, but is kind of at a loss right now.
I'm interested if anyone has had the same problems and what the solution was.
If I find out anything on my end I'll be sure to post it here to help someone else out!
Thanks for the info!
Colin
tblake
08-01-2005, 03:56 PM
my first lumina, 1990 2.5L 4 cylinder had spark and fuel amd still wouldnt start. It surned out being the ECM. Replaced and ran good till the cat converter plugged, so we sold it. Maybe try the ECM both of you.
ctarmen2
08-01-2005, 08:30 PM
I got more news from the mechanic today. He did some more troubleshooting and found that the car will run for about 20 minutes, but when it gets hot it dies. Anyone have any idea what would make it die after getting hot?
Thanks again,
Colin
tblake
08-02-2005, 03:00 AM
that would mean once it enters closed loop it dies. Open loop is when the ecm uses preset paramaters to run the car untill closed loop where it uses sensor data. That sounds to me that it is more than likely be a sensor problem. Was the check engine light on? Ok, lets say you got it running, and after 20 minutes it stalled out, would you be able to start it right up for another 20 minutes then? Get it to stall out and then check for spark. If you dont get spark, replace the ignition module again. Otherwise try maybe the O2 sensor. Umm, I really dont know without actually getting more info. When it stalls out, does it stall because of lack of fuel, no spark, too much fuel? Hard to diagnose over the net. keep us informed, good luck.
ctarmen2
08-02-2005, 04:01 PM
tblake,
Thanks for the information, I'll try to get more information and post what I find out. Can you explain more about the open and closed loop? What makes the ECM transition from open to closed? Is it based on time or heat?
Thanks man!
Colin
tblake
08-03-2005, 12:09 AM
The ECM changes to closed loop when the O2 sensor reaches a certain temperature. Closed loop is when the ECM recieves all the feedback from the censors and uses it to tell the car how to run. (add more fuel/less fuel) Open loop uses minimal censor input , and runs the car off of preset parameters. The fact that your car dies when it warms up suggests to me that its a faulty censor. I still lean by the O2 sensor or ignition module as the cuase of your problem. Start the car, let it run till it dies, and then check for spark with a cheap spark testor that you can buy from wall-mart or anywhere.
meuhus
08-03-2005, 11:37 AM
Mark M
hello
could be injectors too
check them for proper ohms
picon
01-18-2006, 12:58 PM
I hope htis is not too late but I just found this out. My dad owns two Luminas and one of them was doing the same as yours. It would shut off after a few minutes. We checked the battery, alt.,and even changed the fule pump. The trouble was none of the above. Took it to a shop were they did trouble shooting on all the electricle stuff and found that the crank sensor wich is found in the transmission was the problem. Car runs great know. 1992 lumina eurohttp://www.automotiveforums.com/vbulletin/images/icons/icon4.gif
maxwedge
01-18-2006, 04:07 PM
FYI for future reference the crank sensor is at the rear r/s of the engine block.
richtazz
01-18-2006, 04:35 PM
If the service number on your ECM is 1227227, it's a good chance that the ECM is the problem. You can buy a cheap set of noid lights to see if the injectors are getting a signal. If the noid light doesn't flash when the engine is turned over, then the ECM is the problem. 90-93 Lumina's ahad a high ECM failure rate, due in part to it being mounted under the hood and exposed to the elements.
picon
01-19-2006, 09:00 AM
Thank you for that bit of information. I guess it is located near the outerhousing of the transmission, and not in the transmission.
markm2
01-20-2006, 11:50 AM
I found my problems were ing module, 1 of the 3 coil packs was bad and blown fuse for three of the fuel injectors. But now I think it has a BHG can't get air out of system.
Mark
Google
Web AF
