Location of ALDL diagnostic connector on '93 Trooper?
treacherous
07-31-2005, 03:13 PM
Can someone tell me the location of the ALDL diagnostic connector on '93 Trooper? It is apparently a 3 prong connector but all I see under dash is 1 and 2 connector plugs. Is this connector actually behind the instrument panel? I need to pull the codes because my CEL is on. Thanks!
Treacherous
trooperbc
08-01-2005, 12:03 AM
yours should be the same as my 92 trooper.
it's under the trim above, or just in front of, the gas pedal, off to the right towards the hump. [note: "in front of" in this case means towards the seats].
reach up there and gently pull down what will come. or contort yourself with a maglite.
you should end up with two 3-female connectors. one is green, the other is white.
the green one is for the ck trans light [DON'T jumper this one!]
the white is the aldl ck engine light, the one you want.
jump the two outer slots to retrieve the blinking codes.
treacherous
08-02-2005, 08:51 PM
Thanks!
Found it!
