I was installing my deck: out went the lights, clock ext.
Google
Web AF
iToba
07-29-2005, 04:01 PM
I was installing a JVC deck into my 98 Tercel and I am not getting any power to it. I installed by this wiring guide: http://fuzzymunchkin.dyndns.org:8080/tdot/docs/tercel_audio_wiring.jpg
When I test for power I get a reading only though the Accessory line, not through the others. Also, my dash clock, int. lights and trunk lights are not working since I began (yesterday).
Does anyone know if there are wires I may have disconnected? I've checked fuses and all are OK. Any help would be appreciated.
Thank you.
Andrew
tercelandy
08-03-2005, 10:12 AM
you should get power constant through your yellow wire, and power with key on through red wire.
When I installed mine, I sparked something while connecting, and fuse was fine, ended up I had to run a direct power from battery. Double check your fuses, I believe the cigarette lighter, interior lights, clock -all run on same fuse, check on lower kick panel and underhood fuses. If your running a stereo system-(amp, sub) then you could splice your constant right off your amp power wire.
Google
Web AF
