Stratus wont turn over - Fuses keep blowing
Sara Ozmon
07-28-2005, 12:22 AM
Please help, I keep replacing a 20 amp fuse; the car won't turn over at all. I need help locating this problem, anyone?
Thanks - Sara
cficare68
07-28-2005, 12:54 PM
Ok after you replace the fuze will the car start or will it not turn over.
Sara Ozmon
07-30-2005, 06:28 PM
Thanks - Sara
Thank you for responding - it will not turn over at all, no clicks nothing. It keeps blowing the same fuse.
theFREAKnasty82
08-01-2005, 02:33 AM
that 20 AMP fuse, does it control your starter? You have something that shorted to ground, have you had any body work done to the car recently?
eldiablo1100
08-06-2005, 11:21 PM
how long does it take for the fuse to blow?
if it's a short time, you may have a short somewhere
Brent053
08-07-2005, 09:30 PM
Thanks - Sara
Most likely the starter solonoid is shorting out and blowing the fuse. I had the same problem on my 98 and replaced the the starter and solonoid with a rebuilt unit (@ $150.00)
BP
Sara Ozmon
08-07-2005, 10:50 PM
Thank you for all the replys I had it towed in and they replaced the starter. Sara
