02 Leaking Differential Fluid
Google
Web AF
4800Esox
07-27-2005, 04:57 PM
I think I noticed the leak before any damage occured. I was wondering if anyone else had a similiar problem with thier S10 at 80K miles. To me it just seems to early for the seals to be failing
OverBoardProject
07-27-2005, 11:54 PM
When I changed the fluids on mine it had no leaks, and possibly as much as 200,000 miles
It appeared to be the first time that this job was ever done.
bigd7315
07-28-2005, 12:30 AM
i had had several and no leaks and most have had many miles on them where is yours leaking from
bigd7315
07-28-2005, 12:47 AM
4800Esox
07-28-2005, 09:37 AM
I dont know the exact name for the part but its where the shaft enters the differential. The underside of the truck is covered in oil from it spraying around.
I am a little disappointed with the truck. so far I have fixed the starter, electronic fuel assembly, gas gauge, drivers side window motor. All the repairs were easy to fix but it all happened after the warranty was up. I drive my cars into the ground so I plan on having this truck for many many more years. After all a fixng a truck is so much chaeper than car payments.
rlith
07-28-2005, 08:39 PM
My front diff was leaking at the seal for the longest time...(would loose about 2 pints between oil changes) Finally just dropped the bloody thing and put in a new gasket, no probs since.
Google
Web AF
