2005 silverado w/ XM Commander
Google
Web AF
vintage_car
07-26-2005, 11:04 PM
I recently joined the ranks as a happy silverado owner. The truck is just a plain jane extended cab truck. It has just the am/fm stereo. Does anyone know if it has AV jacks on the back of the stereo to plug in the XM commanders FM modulator? If not do they make a factory stereo for this truck that has AV jacks on the back of it? If so a link or price would be great.
Thanks.
3wbdriver
07-27-2005, 07:14 AM
No jacks on the plain jane AM/FM. Yes GM, has a factory XM ready stereo, but I wouldn't know a link, or price. Your local parts dept should be able to help, or check on Ebay. Nice to know some people are still willing to by Plain Jane. This one started out that way last July. One of the add-ons is a Pioneer stereo, and a XM Roady.
Ape0r
07-27-2005, 07:26 AM
This kit uses a pass-thru connector to the radio, works just like GM oem kit, band button changes radio from FM to AM to XM. Install is an easy 30-45 minute operation, depending on how long it takes you to get things apart and back together.
http://www.myradiostore.us/bundles/car/xm-direct-gm-general-motors-xmdgm100.html
jeverett
07-27-2005, 08:29 AM
If your wanting XM radio with the stereo you hav in your truck now, I would suggest a Roadie 2. They are ususally under $100 and take about 20 minutes to install. Everything you need is in the kit, as the reciever has a built-in FM transmitter that lets you choose your choice of stations to broadcast the XM to. I'm actually running a special on them right now. $65 installed. Then you pay the monthly fee.
vintage_car
07-27-2005, 09:29 AM
I haven't had good luck with the Roadie2, the reception isn't that good. I did get an XM commander last night, but no on the search for a headunit with AV jacks on it. THat won't be hard to find, but what is the cost for a harness for an aftermarket stereo?
sportin83
07-27-2005, 10:24 AM
the commander does not need av jacks. its a fm modulator is plugs into your antenna. you will need to get 2 antenna adapters for it though. u need 1 to go little to big and then 1 for big to little. they are usually aroung 8-15 depends on where u get them. any stereo shop should have them. then u put it on a station such as 88.3 fm and then turn commander on and it plays on the radio. its very easy to hook up.
jeverett
07-27-2005, 11:45 AM
Hes right. No need for audio inputs on the commander.
vintage_car
07-27-2005, 01:06 PM
What are the AV inputs on the FM modulator for on the Xm commander?
sportin83
07-27-2005, 09:52 PM
probably if you have a radio that has auxilary inputs on it. i would just use the wired fm mod and be done. the sound quality is really not bad with a wired mod.
2000 Silverado 4x4
07-31-2005, 02:40 PM
Yeah I worked at Best Buy in the install bay and we always used the wireless fm mod. It works just fine, I use the same thing in my truck. When you run the antenna I went through the 3rd brake light and across the back of the headliner down the a-pillar and up under the dash. Or just go through the fire wall and up the weather stripping on the door or windshield. DO NOT RUN THE WIRE THROUGH THE DOOR JAMB IT WILL CUT IT EVENTUALLY AND THEN YOU WILL :banghead:
vintage_car
08-01-2005, 10:28 PM
I got the XM Commander and got it wired up. When the truck is in acc. or just on battery XM doesn't work. It only works when the truck is running. It has to be a wiring problem, but I'm not sure which one? THe 3 wires on the XM are yellow (battery) red/yellow(ACC+) and Black (Ground) I have the Ground going to a screw with metal behind it for a solid ground. I have the yellow going to the orange wire on the stock HU and the red/yellow going to the yellow wire on the stock HU...what's wrong? I swapped the 2 wires and XM doesn't work at all...so the red/yellow has to be right, but is the orange wire on the stock hU not the battery? What color is the battery wire on an extended cab 2005 silverado...
jeverett
08-02-2005, 08:48 AM
You mean the wire behind the factory radio?
Switched 12 volts is yellow. Constant 12 volts is orange.
There are 2 yellow wires also, one is a rear speaker wire, so if you use the "hot" one, be sure to use the one thats close to orange.
vintage_car
08-02-2005, 09:31 AM
I think I remember seeing 2 yellow wires one was thicker than the other...I chose the thicker wire to wire to, but apparently the wiring is still incorrect b/c I can drive the truck and about 2 minutes after driving XM turns off. The truck has to be completely turned off and then the unit will work again...for a couple minutes. I may try the other yellow wire. Any other suggestions?
jeverett
08-02-2005, 09:37 AM
Be sure your commander is getting a constant 12 volts the whole time. I personally would run new wire to the fuse box for the switched wire, and run a new fused wire to the battery for the constant. This is what I do when I install them, but I get paid for it therefore I HAVE to make sure it works and looks good.
vintage_car
08-02-2005, 11:16 AM
Thanks for the help. It looks really good, the working part is another story :) I'll dig out the ol' multimeter and check the voltage.
sportin83
08-02-2005, 01:34 PM
the best place to get your battery power would be under the steeering column. red will be 12 volts, and brown will be your acc with key forward or reversed, the orange will be acc forward. and ground any good metal surface.
vintage_car
08-03-2005, 10:34 AM
Thanks for the help, I thought it was a fluke b/c I listened to XM yesterday all afternoon with no problems, but this morning it was on for about 10 minutes then the whole unit turned off again...Very odd.
Google
Web AF
