wire up a light barD-FOSSE 07-26-2005, 10:35 PM i just bought a light bar for my roof how do i get the wires into my truck do i have to drill? any suggestions will held thanks directory 07-27-2005, 05:05 PM the most direct route is to drill a hole in the roof. not a fun thought. --B SOLSTER 07-27-2005, 05:26 PM the most direct route is to drill a hole in the roof. not a fun thought. --B Any work around ideas that make drilling unecessary? megavolt121 07-27-2005, 06:48 PM http://www.oramagazine.com/pastIssues/0503-issue/050301t-maya-hunter.html check out what they did with using harnesses as quick disconnects SOLSTER 07-27-2005, 07:31 PM http://www.oramagazine.com/pastIssues/0503-issue/050301t-maya-hunter.html check out what they did with using harnesses as quick disconnects I don't get it, they say this: "We ran one pigtail through the roof into the cab" does that mean they drilled? Then what do the quick connect harnesses do? megavolt121 07-27-2005, 07:51 PM the quick disconnect makes it so you can just unhook a few connectors to disconnect the lights(electrically speaking). once that is done, you can easily remove the whole basket/light bar and remount it in a few minutes w/o unhooking stuff. i believe they drilled into the roof underneath the roof racks to hide the hole and wires as much as possible SOLSTER 07-27-2005, 08:03 PM the quick disconnect makes it so you can just unhook a few connectors to disconnect the lights(electrically speaking). once that is done, you can easily remove the whole basket/light bar and remount it in a few minutes w/o unhooking stuff. i believe they drilled into the roof underneath the roof racks to hide the hole and wires as much as possible Thanks! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
