gas no go HELP!!!turtles1118 07-26-2005, 10:15 PM It all started when I was driving around and I came across a big puddle in the street and people were turning around. I thought the hell with it and drove through it and I noticed that when I made it to the other side that my truck had very slow pick-up. When I got to the stop sign at the end of the street I gave it a little gas and started to let the clutch out my motor tried to die, pushed the clutch to the floor and gave it a little gas and almost died agin. The funny part was when I got it into the higher revs it was fine. Got home left it runing and checked the air filter and it was dry. Shut the truck off and it wont start at all help help help jackass#1 07-27-2005, 06:47 AM how high was this puddle? could just have water in some of your wire connections, in your plugs, distributor cap and/or water in your fuel. undo connections and let them dry while you check and dry inside of cap. undo plug wires and let dry out. turtles1118 07-27-2005, 12:31 PM The puddle was about A foot high and maby 15, 20 foot long, and I hit the water at about 25, 30 mph. My father told me to do the same thing and now it starts and runs fine. Thanks for your help. dmbrisket 51 07-27-2005, 11:19 PM now that its been wet you may get corrosion, so it may start to not run correctly after a while rlith 07-28-2005, 08:43 PM pull all the plugs and crank the engine for several rotations. Clean the plugs up and see if it will start. turtles1118 07-28-2005, 10:22 PM well i pulled all the plugs out and every thing semed fine but the plugs were veary black so i went out and got new plugs and wires and wier brushed the ends on the cap. runs like a champ.dose any one know any theing adout cultch woork. my truck has 186,000 miles on it and i dont think any thing has been done with it. it sounds like my P. plate is about shot, it sounds like the plates are rataling togeather. my father told me it was my throw out barings and to drive it till something gos rong. could this be bad? if so whare should i look to get parts. this is my only truck so down time on the truck could only be for a weekend at the max. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
