A/C leaking
Google
Web AF
ta2d1
07-26-2005, 04:50 PM
I'm new here . I have a 94s-10 and It's leaking coolant from the compressor actually it's leaking from the front of it at the clutch. I've talked too a few people and they said there was a seal in the front of the compressor that goes bad on occasion. this is the only place i can find leakage It's so bad that after about 10miles of driving i can see where it's throwing condesation all over the place and the clutch is drenched. anyway does any body know if that seal can be replaced and if it has a part number so i can order it. all the a/c shops want upwards of a 1000dollars to fix and i'm not paying that kind of money for it. thanks for any help.
bigd7315
07-27-2005, 01:39 AM
got to pullapart.com see if the have a location close to you if so go fo getting a used compressor and chaging the whole thing if not try junk yards it is a rare prblem to leak there with out alot of miles on it or a lot of idle time w the air on
rdball
08-09-2005, 04:11 PM
I am a big fan of salvage yard parts, however you might check either AutoZone or Advance auto online. I was browsing AC parts and one of them had the clutch kit and other front compressor parts listed. PS: if the AC shop wants $1000, find a new shop. I can get a new compressor installed and AC recharged for about $300.
paulson
08-09-2005, 05:47 PM
Look on ebay... they have tons of compressors that you can buy...
they also have clutch kits as well
sreed25570
08-10-2005, 10:10 PM
1000 dollars is insane any more than 300 INCLUDING a new compressor is too much i do a/c work very often at the shop yes there is a seal behind the clutch yes it can be replaced however you need a special tool to remove the clutch assy.
you should check arund and find a better a/c shop
Google
Web AF
