97 lumina Steering play
Google
Web AF
aliazhar
07-26-2005, 12:30 PM
i am facing a problem while i drive above 50mph....there is a play in my steering - arround 1 inch.
couple of months ago, i have changed one of the tie rod (front piece)...
any suggesions?....anything i should check?...
thanks and best regards
jeffcoslacker
07-26-2005, 02:32 PM
Tire pressure, tie rods (inner and outer), control arm bushings, steering rack mounts.
Mine slides around on the highway a bit, I see a lower control arm bushing that appears to be falling apart, I think that's the cause...
aliazhar
07-26-2005, 11:38 PM
you are always helpfull :)
the first problem, when i was check the wheels, was that one of my front wheel had two loose bolts...which i have fixed.
i wonder how they got loose this way....anyway, its lot better now, but, i still have to check the play in the steering according to your checkpoints and post afterwords.
thanks again for your help.
Best Regards
Google
Web AF
