cruise controlmitsubishi2001 07-25-2005, 09:24 PM i get 90 camry Dx. the car run great. I have a little problem today, I used the cruise control and suddenly it turned off itself, before it happened about few second the car hesitage. the indicator still on (the button use to turn on the cruise control). I check all the fuse, and vaccum hose, everything is fine. any suggestion of this problem Thank you burchard 07-26-2005, 05:25 PM i get 90 camry Dx. the car run great. I have a little problem today, I used the cruise control and suddenly it turned off itself, before it happened about few second the car hesitage. the indicator still on (the button use to turn on the cruise control). I check all the fuse, and vaccum hose, everything is fine. any suggestion of this problem Thank you Adjust the distance between the brake switch and the brake pedal. I mm more should do the trick. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
