crank but not fire
Google
Web AF
kiser1435
07-23-2005, 02:55 PM
1995 chevrolet beretta
It cranks over but she isnt getting any spark
i changed spark plugs and wires HELP
cficare68
07-24-2005, 04:51 PM
Have you checked the fuel pump.
jsgold
07-27-2005, 12:48 PM
Would imagine that your crank sensor is bad. Only other thing that would not let it fire would be ignition module. Crank sensor should be at front of motor behind balancer. not horribly expensive as a rule. ignition module is expensive and sits under your coils (where your spark plug wires start). A thin item, can be a pain to replace. All of this depends on what motor you have but all 95's have these. get a haynes manual to help you at Advance Auto.
jonsonton
07-29-2005, 12:52 AM
Just some easy check: Check your fuses. Are you getting spark out of all the coil packs?
Google
Web AF
