rodeo 2000 6vd1cam sensor code after cam belt change
Google
Web AF
viclube
07-22-2005, 10:13 PM
I have just replace a cam belt on a rodeo 2000 4 cam v6 6vd1 motor and the cam sensor comes on have replaced the cam sensor and cleared codes still returns next start up
Runs well cel light on or off returns code 41 cam sensor connoted or not
dose the code set when cam timing out 1 tooth ? and has any body got pics or image of cam lobe position as the pulley lines up 3 time to the cam position :confused:
viclube
07-26-2005, 06:48 AM
Yes the fault code is set if out 1 tooth and the valve's don't hit and the car loses the sequential injection goes to grouped instead that the reason for the cam sensor this is on the 6vd1 4 cam motor. I fix my own problem:smile:
Google
Web AF
