abs lite onmacgiver 07-22-2005, 12:51 AM how do you get the ABS dash lite off. f150 99 4 wheel disk way2old 07-22-2005, 10:55 AM Fix the problem that has caused the light to come on. Then it has to be reset with a scan tool that is capable of reading the ABS module. Or you can drive it for a few trips and if it does not see a problem, the light will go out. macgiver 07-24-2005, 11:13 PM Fix the problem that has caused the light to come on. Then it has to be reset with a scan tool that is capable of reading the ABS module. Or you can drive it for a few trips and if it does not see a problem, the light will go out. i checked the pads and put some fluid in the master and disconnected batter but it is still there? way2old 07-25-2005, 09:13 AM You will need to go to a shop that has a scanner that is capable of reading the ABS system. Post codes back and we can help you. cday20 07-30-2005, 04:44 PM i have a 99 as well and noticed my abs light staying on as well. turns out that the ignition when starting stuck to far forward and caused the light to come on. i just turned it back towards me about half an inch with the engine still running and light went out immediately. dont turn it back to far though or you will kill the engine. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
