Auto 2 Manual
~Z~
07-21-2005, 12:45 PM
i found a nice 93 Z32 TT with 94k miles on it for $6000 in the paper here and i wen to talk to the owner and everything seems ok but its a auto and i dont want a Z thats auto so i was wondering how had is it to change a auto to a manual i know K3 did it to his i was wondering if you could post up all the essentials i need and a rough estimate on how much money it would take?
k3smostwanted
07-21-2005, 01:11 PM
hm...are you sure there is nothing wrong with it??? an N/A would be hard to find with that kind of mileage in good condition for that price. just make sure you fully inspect it...because that is one hell of a deal beings they are usually going for double that. but thats not your questions so i will carry on...
the easiest way is to find a wrecked Z32TT manual and buy all the parts from that person from 1 car. make sure you have that person include al of the bolts because you will end up soending another $200 just on bolts that have to be ordered through nissan. i would recommend getting a new clutch and atleast gettign the flywheel resurfaced or else you will probably have to do it all again.
anyways, here is a list of parts...
-TT manual transmission
-manual shifter assembly w/ retaining bracket
-boot and knob
-clutch w/ pressure plate assembly
-flywheel
-pilot bushing
-throw-out bearing & throw-out fork
-clutch pedal assembly w/ depressed switch
-brake pedal assumbly
-clutch fluid line
-custom driveshaft or a similar half shaft
-master cylinder
-metal gusset (sits between transmission and engine)
i know Z1motorsports can sell you everything you need for $1800 or so from them. but if it all possible, i would find a private seller as they are much cheaper but often dont include EVERY piece you need. for example, i bought everything i needed from a guy in New York who wrecked his TT. i paid $850 shipped for everything but i forked out another $250 or so on parts that i still needed. like the gusset that sits between the engine and transmission, the metal retainer for the shifter assembly, all kinds of specialized Nissan bolts that Nissan happens to charge $5 a pop on in some cases (but i happen to have a buddy that works in the parts department).
DeleriousZ
07-29-2005, 07:18 PM
you could always try out that paddle shift kit that's floating around... i don't have the link on hand, but i'll find it if you're interested...
1viadrft
07-29-2005, 09:05 PM
We should probably make this a sticky too... this is asked like every other month....
1viadrft
07-29-2005, 09:06 PM
BTW: I would keep the AT personally....
