water/CO2 sprayerapostrophe28 07-20-2005, 08:54 PM so i was w/ my friend who has a evo VIII and i guess he has a water sprayer that cools the intercooler w/ water. i was wondering if they built these the z32 so i was lookin and found thishttp://www.designengineering.com/products.asp?m=sc&cid=1 i guess its the same as a water sprayer although it sprays CO2 onto the intercooler and it says it will drop the temp of the intake by 60% i was wondering if anyone has used one of these and/or knows of a cheaper kit? ( i can build it myself with just buying the actual sprayers and getting everything else from my local paintball shop) k3smostwanted 07-20-2005, 09:00 PM so i was w/ my friend who has a evo VIII and i guess he has a water sprayer that cools the intercooler w/ water. i was wondering if they built these the z32 so i was lookin and found thishttp://www.designengineering.com/products.asp?m=sc&cid=1 i guess its the same as a water sprayer although it sprays CO2 onto the intercooler and it says it will drop the temp of the intake by 60% i was wondering if anyone has used one of these and/or knows of a cheaper kit? ( i can build it myself with just buying the actual sprayers and getting everything else from my local paintball shop) there are 2 different systems... they have what is called water injection or water/alcohol injection which sprays a fine mist of liquid into the air stream to mix with teh air and effectively lower the temperature of the intake charged air. another way is to spray a chemical like nitrous or CO2 onto your intercooler. which basically cools down your intercooler and lowers the temperature air in your intake stream non-directly. both ways work...the first system would probably be a little more difficult to make because it would have to work perfect. if the second system failed...it would not cause a problem. your intercooler just wont cool down. i dont know which type your friends has...but im guessing it may be like Fast and the Furious where he had a oval bar that sat in-front of the intercooler. Broke_as_**** 07-20-2005, 09:12 PM Well if all you are going for is an intercooler spray (ie external to the intake system) then all you would need is the CO2, something to spray it out of mounted on the intercooler and a way to trigger it. But this method of course is temporary at best. Mostly this sort of this is used in drag racing and dyno pulls. k3smostwanted 07-20-2005, 09:19 PM But this method of course is temporary at best. Mostly this sort of this is used in drag racing and dyno pulls. didnt Wagz use an external CO2 spray on his Z32TT when he pulled that 744(?)rwhp? Broke_as_**** 07-20-2005, 09:28 PM Yes he did, I got the video of that somewhere. Sprayed his front mount with CO2 or nitrogen or something else cold right as he laid into the throttle. EDIT: Here it is http://www.streetneeds.com/uploads/videocars/wagz744.wmv The link doesn't seem to want to work so just open Windows Media Player, go to "File" and "Open URL" and put the link in. <SSR>David 07-20-2005, 11:27 PM wow thats pretty cool. Never seen it being sprayed before. ^^ k3smostwanted 07-21-2005, 12:30 AM Yes he did, I got the video of that somewhere. Sprayed his front mount with CO2 or nitrogen or something else cold right as he laid into the throttle. EDIT: Here it is http://www.streetneeds.com/uploads/videocars/wagz744.wmv The link doesn't seem to want to work so just open Windows Media Player, go to "File" and "Open URL" and put the link in. ahh...thanks broke. that would be the video clip. very nice...i have a video of him giving people rides in his Z. thing sounds like a beast but he has his cam durations set so it lacks a good, clean idle...kind of reminds me of a carbed V8 until he gets higher in RPMs, then the Z sounds bellows through. ill try to find it.... Broke_as_**** 07-21-2005, 03:25 AM ill try to find it.... http://www.z32power.com/69109721152313/blank/browse.asp?A=383&BMDRN=2000&BCOB=0&C=52923 Probably in there somewhere. k3smostwanted 07-21-2005, 01:25 PM i didnt see it on there....if someone gives me a good place to host videos i have a couple downloaded on my computer that some might like to see. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
