Transmission fluid/DIFFERENTIAL FLUIDrubs 07-19-2005, 12:27 PM Hi, I have a 98 camry and the transmission fluid was change at 60k and now it is 120k so need to change again. I was checking the schedule and found DIFFERENTIAL FLUID. What is this fluid...is this same as transmission or different...Do it also need to be change with transmission or 1 is the subset of another....how often this fluid should be change? Thanks --rubs Toysrme 07-19-2005, 06:45 PM Differential fluid is ATF - Any dexron III compatible. It's not exposed to lots of heat, not much wear. Normally it's never changed. The specification is to change it with the transmission fluid - Every two years. (Yearly, if you're smart - yearly and adding an AUX cooler if you're a genius). vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
