Starter Issues
Google
Web AF
dreakian
07-19-2005, 10:57 AM
Here is my problem with my 2001 blazer..
After the Engine is started the starter restarts after a couple seconds ( grinding horribly )
Ive replaced the Starter,Ignition switch and the Starter relay but it still has the same problem.
I even removed the cam that goes into the lock cylindar and turned that cam by hand ( bypassing the key alltogether ) still same problem.
IF after starting the motor I remove the relay the starter stops and everything is well..
Any other possiblilities I could look at ?
Thx in advance for the help :)
BlazerLT
07-19-2005, 11:21 AM
Ignition switch is sticking.
dreakian
07-19-2005, 11:55 AM
I allready replaced the ignition switch ( the part with the wire harness )
I opperated the switch out of the column by hand.
bad new switch ?
thx for the reply :)
Google
Web AF
