95' S10 2.2 Fuel Pump constantly runs...
Google
Web AF
BradleyB1
07-19-2005, 09:48 AM
Weird problem. On my 1995 S-10 2.2L, after I turn off the ignition and have my keys in hand, the fuel pump continues to run. It will run until it kills the battery. Only way to stop it is to pull fuse #9 in the cab. Any ideas? Could a faulty fuel pump relay cause this? On this truck, the realy is in the glove box, right? Any ideas would be great, thanks!
jackass#1
07-19-2005, 08:03 PM
no the relay shouldnt even have power to it when off. id start with ignition switch. that would be the only thing i could think of that would be at fault. somehow when you shut it off the switch isnt shutting the pump off.
rustbucket
07-20-2005, 12:03 PM
On some vehicles there is a oil pressure switch that powers the fuel pump when there is oil pressure. I am not sure about the wiring, but maybe it could be doing it.
BradleyB1
07-21-2005, 07:39 AM
Thanks for the replies, I will try to check both those possibilities this weekend.
Google
Web AF
