Rear brewak drums stuck help?
Google
Web AF
ksgtinv
04-26-2002, 05:30 PM
Does anyone know the best way to remove rear break drums that are stuck on? Any help would be appreciated.
drschwarz8566
04-28-2002, 05:46 AM
typically you can heat the drum where it is held on and then hit it with a mallet and it will pop loose.
BP1badF150
04-30-2002, 10:51 AM
Usually a few hits with a hammer work but if they aren't backed off, then they are a real bitch:smoka:
loy
01-10-2004, 12:46 AM
with wheel removed, put on a lug nut flush with end of bolt, turn hub so bolt will clear break parts inside, knock bolt through with hammer, put a good big screw driver in hole between hub and axcel and hit it with a hammer. that will seperate it.
Google
Web AF
