2000 Blazer A/C Cooling Problem
Google
Web AF
mrswans
07-18-2005, 10:41 PM
It has been about 90 and very humid here recently. On the last couple trips of 30 miles or so the A/C starts blowing hot for the last 10 miles. In town it seems to cool fine, but not as cool as normal. I checked the low side charge and it is close to 40 psi. I looked at the compressor when it was blowing hot and it wasn’t engaged. Any ideas?
Thanks,
Mike
BlazerLT
07-18-2005, 10:47 PM
Did you test with AC on MAX with the fan on ful blast?
mrswans
07-19-2005, 06:04 AM
Thanks,
Mike
I checked the pressure with the A/C on Max and the fan on high.
BlazerLT
07-19-2005, 11:19 AM
Check the low pressure switch if the compressor is not coing on.
mike2004tct
07-19-2005, 03:44 PM
Also look for the AC relay, I had a bad contact on mine. I found it by first hot-wiring the compressor to make sure it worked, then started tracing wires until I found the busted contact.
mrswans
07-19-2005, 10:17 PM
Hi, where would the relay be located?
Thanks,
Mike
mike2004tct
07-20-2005, 07:25 AM
Thanks,
Mike
Relay access door is inside the glove box. You should be able to swap the AC relay with the fuel pump relay, a quick swap will tell if it's a bad relay. Also inspect the wires at the block the relays plug into.
mrswans
07-21-2005, 10:33 PM
What is the easiest way to check it? Is the low pressure switch isolated from the freon?
Also, what is the connector that looks like a switch on the back of the compressor?
Thanks,
Mike
mrswans
08-05-2005, 09:30 PM
Thanks,
Mike
Does the freon need to be emptied and recharged replacing the low pressure swithch?
mike2004tct
08-06-2005, 10:00 AM
No. The switch fitting has a pressure bead in it,such that it can be replaced without losing any refrigerant.
mrswans
08-06-2005, 09:17 PM
Great, thanks
mrswans
09-17-2005, 05:33 PM
Replacing the low pressure switch fixed it.
thanks all
BlazerLT
09-18-2005, 06:58 AM
Excellent!
Google
Web AF
