is there supposed to be an air readout on safc II?
HoosierDrifter
07-16-2005, 04:43 PM
ok... car still running rediculously way too rich.... i noticed going through the monitors on the safc II that its not reading anything for air... is this normal? or should it be reading somthin?
nissanfanatic
07-17-2005, 05:36 PM
There should be an airflow %, Throttle%, RPM, and correction%, and you should even have a knock display. Make sure you select the highest number of channels to get as many readings as possible. And in sensor check, there should be in-1 voltage and in-2 voltage as well as TPS voltage.
I have never used the SAFC 2, but I use the SAFC all the time. When Tat gets on, he should be able to hook you up with some more accurate info.
HoosierDrifter
07-17-2005, 08:29 PM
hmm well... i have hooked everything up correctly... and it shows rpms and throttle % but when i go to "afl" it reads nothing..just stays at zero... i have tried two different mafs.... nothing... im about to hook up my stock 240sx maf and see what that does.
nissanfanatic
07-17-2005, 10:40 PM
You have it wired wrong...
SAFC install (http://web.ics.purdue.edu/~tmerrick/240SX/apex_safc.htm) This is for the SAFC 1, but it will still show where to cut and solder the air flow meter wire.
