1996 dodge ram 1500 4x4....2 problems
View Full Version : 1996 dodge ram 1500 4x4....2 problems 1996 dodge ram 1500 4x4....2 problems mantis_tn 07-16-2005, 04:15 PM I am having transmission troubles....It is not wanting to go into higher gears....so, today I went to get the fluid flushed and replaced. The mechanic at the shop informed me my oil pump was not functioning. Is this going to cost an "arm and a leg"???? problem2: warping rotors.....it only took 6 months after replacing my rotors for them to fail. Is there a brand or type of rotor I should use that will last longer? Blylock 07-17-2005, 06:10 PM problem 1: I am having transmission troubles....It is not wanting to go into higher gears....so, today I went to get the fluid flushed and replaced. The mechanic at the shop informed me my oil pump was not functioning. Is this going to cost an "arm and a leg"???? problem2: warping rotors.....it only took 6 months after replacing my rotors for them to fail. Is there a brand or type of rotor I should use that will last longer? if your oil pump was not functioning you would not have any gear. sounds like you burnt out your 2-3 clutch. rebuild it sounds like your hard stopping on your brakes. its not the rotors, if anything its your pads. cheap pads heat up rotors and cause warping. try using ceramic pads Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
