Rough Idle and Running305V8 07-14-2005, 10:08 AM 1997 F-150, 4.2L, 120,000+. I have a similar problem as some of the other posts. After truck warms up, idle still seems high and truck runs rough at all speeds and idle. Feels rough during acceleration. Sometimes when shifting from 1st to 2nd and from 2nd to 3rd, engine surges for 2-3 seconds after backing off accelerator. When stopped at intersection, sometimes engine will idle high and sometimes will drop down to near normal. I've replaced plugs and will replace wires today. O2 sensors were replaced six months ago. Checked EGR valve and found no blockage. Pulled IAC and it looks OK, no blockage. After replacing plug wires, I'll check the spark at the coil. The TPS is attached with two Phillips screws that are EXTREMELY tight and I could not get them off to check the sensor. How can I get the TPS off without damaging it, or should I just try to drill the screws out and replace them and the TPS? Can I spray throttle cleaner in the IAC and brush it out with a small toothbrush? It doesn't seem that dirty, but maybe there's something in there that I can't see. Anything else I should check/replace? fdunford 07-14-2005, 02:58 PM Could be TPS I guess. If you unplug the TPS connector it might (should?) go into FMEM mode and use a default value. You can use an ohm meter to test the TPS as it's just a simple pot with a wiper going back to the PCM. Did you check you fuel pressure at the rail? It should be somewhere around 40psi. firefighter3110 08-01-2005, 01:39 PM Hey I had this problem after I put a non-stock exhaust on, rough ideling, crappy accel, poor shifting and sometimes it would bog, after a yr of messing with it i took it to the shop. They said it was the air temp regulator and my K&N filter (the oil used on te filter) might of burnt out the sensor. They changed that and it didnt change anything, so the guy started trouble shooting again, it was a linkage from the back of the manifold to the PVC/PCV?? valve, their was a huge hole in the top part of the linkage connecting to the valve and the guy said it must be a pretty typical problem cause the ford dealer had a few in stock, so im guessing its pretty easy to replace and not that expensive. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
