coolant tank leaking
wally91vhevrolet
07-13-2005, 10:09 PM
my coolant tank has sprung a leak... lol... its a SMALL ASS hole and it sprays a REALLY THIN stream of coolant out when its up to temp or close... is there any kind of patch or somethin i could put over this? or do i have to replace the whole tank? thanks for ur help
KimMG
07-14-2005, 01:31 AM
If it is a small hole, you can try a sheet metal screw with some sealer on the threads.
wally91vhevrolet
07-14-2005, 07:10 PM
update, talked to my friend thats a mechanic... he said he sees this a lot with fords and said i should replace the whole thing... he said u can go the screw w/ sealant or even buy patch kits but they dont work for more than 1000 miles... so i went to a local garage and a guy had aftermarket ones in stock sellin them for $30 a pop.. got one n now im on the road again
TSPhelan
08-15-2005, 11:44 AM
Can you tell me name of garage you called?? Can't find anyone w/ aftermarket parts for my 2000 Taurus FFV. Love the car, but mechanically it is a nightmare!
Mimiamy
10-20-2005, 10:49 PM
I had the same thing on my 98 Taurus and unsuccessfully tried a two part plumbers putty, good to 250 degrees. I ended up buying a brand new coolant tank, for 32 dollars, at a Ford dealer. About 20 min. work, and it was done.
NeoSNightmarE
10-21-2005, 10:33 PM
same thing with me. '99 SE. i was pissed. but its best to just replace the thing in the end. patching does basically nothing.
sparrbq
10-25-2005, 08:34 AM
Mine is a 1997, had the "pin-hole" leak replaced it with a new one.
Just replace it I say and You wont have to worry about it again.
Easy & quick to swap out too.
