Our Community is 662,000 Strong. Join Us.
2000 Quest problems (fuel filter location & stuttering)
ridgraycr
07-10-2005, 09:08 PM
I'm trying to locate the fuel filter for a 2000 Quest. Its not shown on the owner's manual and I can't find it when I look under the hood.
I also recently changed the spark plugs for some Bosch Platinum +4 plugs, and I've noticed a little problem with the idle. Seems like a spark plug is failing or should I check the calibration?
mrp2946
10-20-2005, 03:56 PM
Were you able to locate the fuel filter? I am having trouble locating mine as well on my 2000 Quest.
nissan01
12-18-2005, 07:53 PM
fuel filter located under driver seat(under the car) you have to remove the plastic cover
don't use bosch plug, you must buy original plug for nissan, because they use lazer platinum point, otherwise you may damage your engine
