98 Accord Brake Lights outjkberry4 07-10-2005, 06:27 PM The brake lights on my 98 accord don't seem to be working. The rear lights work, but when the brake is applied, the lights do not come on. I have checked fuses, and that doesn't seem to be the problem. Any other ideas would be appreciated. Thanks. woofhaven 07-10-2005, 08:40 PM Check the switch activated by the brake pedal. Then check the bulbs. The '98 accord has a dash light that comes on if a bulb is out. If that light is not on, then you probably have a bad switch. jkberry4 07-10-2005, 10:21 PM Thanks a lot for your help, I will give that a try. blacknight 07-12-2005, 04:53 PM Also, check too see of your horn works. The horn and the brake lights share the same fuse. If the horn doesn't work, then it's the fuse under the hood. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
