2001 Explorer Over heating
TXstang347
07-07-2005, 06:21 PM
My 2001 Ford Explorer overheats within about 10 to 15 mins.
Symptoms: There is power loss in 2nd gear at about 15 to 35 miles per hour, it feels like the transmission is missing shifts, no accelerated response, the A/C comes and goes, and the check engine light came on 2 weeks ago. Any likely suspects? Thermostat, water pump? There are no leaks and all fluids are topped off, including radiator fluid and resivior.
Much Thanks!
Baranis
07-07-2005, 07:25 PM
I would start with replacing the t-stat from Ford.
Aftermarket t-stats are designed different and Ford's
temp monitoring is sensitive.
When you buy an OEM t-stat from Ford it may not include
the O'ring. Be sure to get a new O'ring from Ford.
Just my opinion.
exploded99
07-08-2005, 06:13 PM
Much Thanks!
A/C has a cutout switch when the engine gets too hot. Get the code read at an auto parts store. Autozone, Checker some others do it for free.
