Help Me PleasetHe StEeleR 07-06-2005, 02:41 PM I have taken the trans pan off, and the trans fluid filter out, but the o-ring is stuck in the trans still...... how do i get it out without damaging stuff? b tw its a 96 3.1 L GTP Dad 07-06-2005, 06:53 PM A dental pick with a sharp metal end will work the best but if you don't have one then use a piece of wire and sharpen the end slightly, a heavy paper clip should work. Put it up inside the hole and you should be able to push it into the O-ring and pull it out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
