Police style Center caps?thermal izod 07-04-2005, 03:31 PM I've got a base model Impala...the wheel covers are starting to look really beat up....very suddenly they are peeling up and looking weathered...I'm not willing to spend tons of $ on rims (not to mention it's hard to find any i like), and spending $50-100 on replacements seems stupid, considering my impala is 5 years old, been in florida the whole time, and the current caps are already looking so bad at 50K. On to the question....anyone know where i find cheap police style center caps? I'm willing to just ditch the covers totally....i've been looking on ebay.com under "2000 impala center caps" but I'm only finding the caps for the LS style alloy rims....anyone that can give me a heads up on this would be great....thanks! Fun driving..... bigrod118 07-04-2005, 09:31 PM yeah when you search ebay, use impala police center caps thermal izod 07-04-2005, 11:19 PM thanks, nothing there currently...but i'll keep checking... bermis519 07-05-2005, 10:55 AM just type in "impala police". Thats where i got mine.... mike thermal izod 07-06-2005, 05:23 PM anyone know any online retailers where I can get a good deal on center caps and the rings for the outside of the rim? i'm having trouble finding anything, anywhere... thermal izod 07-25-2005, 09:28 PM ok, i finally found some...how did everyone install them? i'm thinking drill the 3 mounting holes, then use the kit-included mounting bolts and some locking nuts on the back? any input from those that have done this already...please... Pat_OD 07-27-2005, 08:31 AM u cant use locking nuts on the back not enough room. the wheel goes right up against the rotor. You'll need to thread the holes with a tool bermis519 07-27-2005, 10:47 AM Make sure when you drill through those rims that the cap is centered or the tire is going to be off balanced. I went to the hardware store and bought the skinniest nut i could find. I noticed that it butts right up against the rotor. If you do it right and becareful doing it it will work just fine. Mike thermal izod 07-27-2005, 08:22 PM thanks for the info...i was able to thread the hole, and it's a perfect fit... jbs80106 08-23-2005, 10:27 AM Hi! Hope this is still an active thread. I'm doing the same thing, got the center caps w/mounting screws but need to drill the rims. Do you recall what size hole/bit you used? Also, did you actually have to tap the threads into the hole or did the screws just tread in? Thanks! jbs80106@yahoo.com thermal izod 08-24-2005, 02:43 AM i can't recall the bit size...but i know u'll have to tap the treads in....it won't thread itself. thermal izod 09-03-2005, 07:57 PM To those who choose to replace hubs w/ center caps: We advised that when I did mine, the caps had rubbed off some paint on the rims, mostly around the outtermost edge of the rim, and some in the center, where the hubs' metal clips touched...This caused some rust a month or so later....I was able to bust it off w/ sandpaper, then use some GM black touch up paint to cover the naked area. I recommend to anyone who switches to center caps to check the rim for scratched, worn, or chipped pain and touch it up before a corrosion situation arises. Just a heads up, I was lucky enough to spot it early and remove the corrosion before it got bad....hope the same for everyone else... MCO_Death 09-04-2005, 07:19 PM To those who choose to replace hubs w/ center caps: We advised that when I did mine, the caps had rubbed off some paint on the rims, mostly around the outtermost edge of the rim, and some in the center, where the hubs' metal clips touched...This caused some rust a month or so later....I was able to bust it off w/ sandpaper, then use some GM black touch up paint to cover the naked area. I recommend to anyone who switches to center caps to check the rim for scratched, worn, or chipped pain and touch it up before a corrosion situation arises. Just a heads up, I was lucky enough to spot it early and remove the corrosion before it got bad....hope the same for everyone else... Common, easy fix for the wheels really. When I had first gotten my Impala, there was a lot of worn off paint on all four wheels, Mostly the outer-most exposed rib. I just sanded them down and hit them with a glossy rust-proofing paint. Been nice and clean looking ever since. thermal izod 09-04-2005, 10:49 PM exactly... MCO_Death 09-06-2005, 09:37 PM exactly... Now I just have to deal with repainting the rest of the car :banghead: CHEVYdriver89 09-07-2005, 08:02 PM Where did you get your Caps thermal? thermal izod 09-08-2005, 03:06 AM ebay...took a while to find them, and it was a tough win...these are hard to get ur hands on, apparently... MCO_Death 09-08-2005, 09:12 PM ebay...took a while to find them, and it was a tough win...these are hard to get ur hands on, apparently... Bring the right size wrench and be quick at night in a police parking lot ... Oh... You mean legally. Gotcha. spacemoose39 10-24-2005, 06:51 PM I've got a base model Impala...the wheel covers are starting to look really beat up....very suddenly they are peeling up and looking weathered...I'm not willing to spend tons of $ on rims (not to mention it's hard to find any i like), and spending $50-100 on replacements seems stupid, considering my impala is 5 years old, been in florida the whole time, and the current caps are already looking so bad at 50K. On to the question....anyone know where i find cheap police style center caps? I'm willing to just ditch the covers totally....i've been looking on ebay.com under "2000 impala center caps" but I'm only finding the caps for the LS style alloy rims....anyone that can give me a heads up on this would be great....thanks! Fun driving..... Dude, i know this post is a bit old, but if your still looking i just came across this on ebay: http://cgi.ebay.com/ebaymotors/IMPALA-POLICE-wheel-hub-cap-2000-2001-2002-2003-2005_W0QQcmdZViewItemQQcategoryZ33744QQitemZ800969 4783QQrdZ1 Hope this helps. thermal izod 10-25-2005, 06:04 PM i already got them...thanks though, i appreciate it. spacemoose39 10-25-2005, 06:14 PM i already got them...thanks though, i appreciate it. Hey no problem,have you taken any photos of your impala with the nices caps? thermal izod 10-27-2005, 03:11 AM i plan to take pics real soon-next time i wash it. i'll post 'em when i do... MCO_Death 10-27-2005, 07:23 PM i plan to take pics real soon-next time i wash it. i'll post 'em when i do... We will await then. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
