A few Questions, 94 LHS
brunetp
07-03-2005, 05:43 PM
3.5L engine "codes 33,33 and 35" does anyone know what these mean?
My radio won't work?? i hear hissing but thats it. There's no clock or illumination even when i'm using it on the CD player, could the antenna ground or somthing like that be causing it or is the sterio screwed?
I am also investigating an oil leak somewhere, i still can't find where it's leaking from, could be the camshaft seal, crankseal(i doubt it, no visual oil behind pulley), oilpan seal or maybe the oil sending unit plug area?? anyone know of any common problems with 3.5L engines and oil leaks?
And one more thing, The crank flywheel pulley wobbles when the engines running, it blew off both belts last night when i floored it passing a car last night, anyone have any info on that??
Comments would be appreciated, thanks!!
drifttagr
03-29-2006, 07:23 PM
mine was leaking too it was a spark plug gaskets and a manifold gasket
