Odometer/Gear Displaycgreen6120 06-29-2005, 09:07 PM My 99 Silverado odometer was going out intermittenly now its out for Good ??? Can anyone help me! ?? silveradoman 06-29-2005, 10:29 PM Cold solder is your problem, if you´re good at hobbiing you can try and desolder the whole thing to look for the cracked solder joint or you can buy a new one. cgreen6120 06-29-2005, 10:36 PM Cold solder is your problem, if you´re good at hobbiing you can try and desolder the whole thing to look for the cracked solder joint or you can buy a new one. I am pretty good at soldering , Is the cluster hard to get out ? do i have to resolder everthing or try and find the cracked joint? jethro_3 06-30-2005, 01:52 AM Getting the dash out is easy. To get the part disassembled to the pc board takes less than a half hour. Put the e-brake on, turn key on, tilt wheel down(if availible), put trans into 1st (if auto), pull 4 screws around dash pod, remove front and back parts from dash assembly. Good Luck cgreen6120 06-30-2005, 07:57 PM Getting the dash out is easy. To get the part disassembled to the pc board takes less than a half hour. Put the e-brake on, turn key on, tilt wheel down(if availible), put trans into 1st (if auto), pull 4 screws around dash pod, remove front and back parts from dash assembly. Good Luck I DID IT!!! :):):) I FIXED IT!!!!! THANK YOU!!! Saved me 250.00!!! I found a loose solder joint going to the display It was the like ten little wires going from the board to the display baord, it was number one Thanks again!!! Claey Green ( Spanky ) cgreen6120 06-30-2005, 08:00 PM I am pretty good at soldering , Is the cluster hard to get out ? do i have to resolder everthing or try and find the cracked joint? I DID IT!!! I FIXED IT!!!!! THANK YOU!!! Saved me 250.00!!! I found a loose solder joint going to the display It was the like ten little wires going from the board to the display baord, it was number one Thanks again!!! Claey Green ( Spanky ) jethro_3 06-30-2005, 08:39 PM Got so excited you had to say it twice :bananasmi ???? dbl post. Congrats, hopefully no major items were left off the directions like block the wheels so the truck does not roll away when the e-brakes don't work.... :22yikes: cgreen6120 06-30-2005, 08:44 PM Yes I did! Sorry I was just so proud of myself! I got excited! :) jethro_3 06-30-2005, 08:54 PM Can't blame you, excitement can do funny things to a person... Just glad to hear that the info helped!! :cool: vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
