Smokey brakes?
View Full Version : Smokey brakes? Smokey brakes? ctp_mechanix 06-25-2005, 08:04 PM PC-Gamer 06-26-2005, 10:40 AM I also have the same problem but on a 2000 Chevy Camaro 3.8. I put new pads and rotors on yesterday and drove it about 5 miles and it smokes from both front wheels, but not the back. It has 4 wheel disc brakes and the back seems to be fine just the front smokes. Anyone have any suggestions as what may be causing this? The pads I bought were from Autozone, they're the $20. Lifetime warranty pads. ctp_mechanix 06-26-2005, 11:12 AM my pads were the 20 dollar pads to with a warranty... but i think i trew away the box. but they took my info at the store PC-Gamer 06-26-2005, 02:40 PM Well after driving mine for another 2 miles the smoking is now gone. So I'm going to assume it was just the brakes being broke in. The rear brakes are the same manufacture pads as the front and they never smoked. So I'm ruling out that they are bad pads and it was just a break in issue. ctp_mechanix 06-27-2005, 02:24 PM well mine hang up a little... i onno.... they all went together fine,, but it's fucked up cuz it's on both wheels.... and everything should have been together fine MagicRat 06-30-2005, 11:22 PM Sometimes if you re use the calipers and just push the piston back in, the calipers drag. This is because the caliper bore is a bit rusty and/or the O-ring for the piston is not in correct orientation. Either way, the piston is not retracting from the rotor enough. Generally a really good brake job involves replacing the calipers. Re-using the old calipers usually works, but not always. Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
