Using vitara pistons for boost???
ffubar
06-22-2005, 02:32 PM
Hey peps, i have been told that on a Honda's D16Z6 engine, SOHC VTEC, i can use Suzuki's Vitara pistons in the oem block to have lower compression and to allow me to raise my boost! Is this true??? I can't find anything else regarding this!
If so, what pistons should i be looking to get, year, make, model of engine!
How much boost can i run???
97integrals
06-22-2005, 05:41 PM
I know nothing about d16's but I have seen some threads about this in the forced induction forum over at www.honda-tech.com I would search over there or at www.turbod16.com
Schister66
06-22-2005, 06:30 PM
Yes it is true. One of the guys on turbo D16 just made tons of power on Vitaras.
honda_racing101
06-23-2005, 10:41 PM
Well, even if the C/R is lower you wont be able to run TONS of boost or else the rods will crack, or the pistons rings will fry. I know nothing about Vitaras pistons, but without other bottom end mods you'll have a hole in your block nice and quick.
duffman868
06-24-2005, 02:05 AM
while you have it apart through in some aftermarket rods and then rebuild with arp hardware. after that the thing that would break next would be the sleeves
lkailburn
06-24-2005, 09:00 AM
how much you can run depends on your tuning but you should be able to run a nice safe 250whp~270whp+ without even worrying about the bottom end(assuming you have some nice rods and a GOOD tune)
hmt, turboD and d-series.org is where you'll find what your looking for
