1991 honda accord s light blinking
embarn
06-21-2005, 09:35 PM
Hello was wondering what codes mean I have the s light on a 91 accord blinking did the test where I connected the jumper it would blink 7 times then repeat tried calling around to see if anyone had a helms manual but they all want me to bring it in and let them fix it also the ecm called out a code 6 which was coolant temp sensor changed that and reset fuse still have that code was wondering if there was another coolant senser other then the one on the water neck next to the distributer tried emailing the group but came back to me as an errored message any help will be appreciated thank you and have a nice day
embarn
06-21-2005, 09:38 PM
also tach and speedometer still working good
embarn
08-14-2005, 10:30 PM
Ok just putting this in for anyone who is searching for the fix of the 7 blinks after changing the speed senser and the tcu 2 times finally went to the junk yard and got the 2 shift selonoids (I think thats what they are called) the 2 things under the rubber trans hoses behind the radiator held in by 3 number 10 metrric bolts each but fixed it runs great hope this helps
